Jura S9 Problem
Ich habe ein Problem mit meinem S9.
Das Wasser, die coming out, wenn Sie Kaffee macht ist sehr sehr langsam.
Es dauert viel länger als zuvor.
Außerdem ist die Menge an Kaffee gemacht wird weniger bekommen.
Irgendwelche Ideen wäre was Problem bitte.
Vielen Dank
Hello
I have a problem with my S9.
The water coming out when it is making coffee is very very slow.
It is taking much longer than before.
Also the amount of coffee being made is getting less and less.
Any ideas what problem could be please.
many thanks
Yep, I guess it's the old known problem meaning a calcination within your system. It's not a doddle to find out but I would start to clean all inner tubes and valves. Especially at the end of this tubes there is quite allot of calc. You have to remove all tubes to fix it.
Another hint is to clean die blast pipe in the slider. This was an issue I had.
Koffee power is still dry not very wet?
Hope it helps!
HEM
Gast schrieb:Yep, I guess it's the old known problem meaning a calcination within your system. It's not a doddle to find out but I would start to clean all inner tubes and valves. Especially at the end of this tubes there is quite allot of calc. You have to remove all tubes to fix it.
Hope it helps!
HEM
Problem solved??
HEM
Letzter Beitrag: herwig81
  Jura J6 Stromverbrauch...Problem ralf_pr 1 3.285 21.10.2022, 08:27
  Jura E75 Problem Wasduwolle 4 11.470 19.06.2017, 14:12
Sad Problem mit Jura S9 juras9 14 33.560 09.12.2015, 09:14
  Jura E80 Problem Kaffeejunkie 7 27.662 02.09.2012, 15:03
  Problem mit Jura Impressa E25 harry2212 2 8.566 10.09.2009, 09:47
Letzter Beitrag: harry2212
