Jura Z5 Hilfe bitte
Hello everybody.
I apologies for writing you in English but my German is good enough to talk/read but not to write.
I hope someone can help me with the following 2 problems I have with my Jura Z5. The machine is from 2008
The first problem started about 4 months ago. When I make a cappuccino the milk works fine but the coffee is only coming a little bit. I think the switch is broken. I have checked if the switch is clean and that is the case. What part do I need?
The second problem is recent. If I switch on the machine the display gives me "fill system". When I press the button, I can hear a light buzz but nothing happens. What is broken?
I can't use the machine now Sad
Many thanks for your reply
Ron
Hiya Ron
It seems to be a calcination inside the water system. Take the water flow plan and clean up all tubes and connections.
Feel free to ask for more details if necessary.
Jurist schrieb:Hiya Ron
It looks like the'warmtetauscher' is really calcified.
The tubes and connections looks fine.
Could this be the problem?
I just realise that this cannot be the problem. Yes,it is leaking water and need replacement but should not stop the waterflow
Checked all tubes and all clear.
As I don't hear the pump when I tested it, it could well be that this is broke.
No noise of the pump even no buzz? Pump getting hot? Are you sure that the water flow from the tank to pump is OK? Remove the tube and suck water to test that there is no jam. Leaking water can deamage the pump as well as other electric elements. Make sure to fix it. Be aware of 220 Volt electric power! I assume the pump ist broken because of water dripping in. Not sure about the ceramik ventil. You also have to check about water demage as well.
You may consider that a flat rapair price is the better option...
Take care
  Ratlos Error 8 Jura ENA Micro 8, Bitte erst lesen JK66 5 1.650 17.04.2026, 10:14
  Impressa s70 - Bitte Warten - Oberer DLE Oelfchen 7 7.385 07.06.2023, 05:35
  Jura s90 "Bitte warten" joeylu 2 5.021 06.09.2021, 08:34
  Jura Impressa Ultra zeigt -Bitte warten- Schnico85 21 36.182 18.06.2020, 09:29
  JURA -J9 Brauche Hilfe!!! Fh1607 1 6.110 30.06.2017, 13:10
Question Bitte um Hilfe Jura Impressa J9 Wasser unter der Maschine KölscheJung 1 11.954 23.01.2017, 10:18
Toungue Bitte zuerst lesen: Hilfestellung zu Jura - Störung 1,2,3,4,5,6,7,8 - System füllen BND-Kaffeestudio 0 118.077 21.08.2015, 17:19
  Bitte warten sehr lange Stromer 10 25.323 15.02.2015, 13:33
  Jura Impressa E40 - vorne rechts undicht - Bitte um Mithilfe bei Fehlerdiagnose rednoserudolph 3 14.288 11.02.2014, 02:53
Letzter Beitrag: rednoserudolph
Cool Hilfe Selbstbedienung! Jura Impressa S 70 Maxwell53 3 14.566 19.02.2013, 10:56
